Tracker for UIQ - save 30% from PDATopSoft.com
pdatopsoft.com/software/item.php?pid=8962
Tracker is a real and fully customizable desktop application. With the special skin system it looks and acts exactly like you want,
offering you hundreds of unique functions and possibilities transforming your device from a simple organizer to a powerful and great
looking handheld computer.
Tracker is used as a desktop. You can place any number of sticky notes, shortcuts to applications, documents, speed dials, speed
SMS, speed MMS, webpages, contacts, etc on your desktop. You can drag and drop these shortcuts to any other place on the desktop or
to the recycle bin. Icons could be native (native application icon, a picture in a contact) and fully customizable (you can select
any image in any size to use as a shortcut icon).
It has Today view with: Summary view (shows brief information for today) and Day view (shows complete day information for a day
from your Calendar); Week view (shows complete week information from your Calendar), Month view (shows month overview from your
Calendar), Tasks view (shows Todo information from your Calendar), Messages view (shows and maintains your messages). At the end of
each voice call Tracker displays "Call duration" on the screen [Disabled for Motorola a920/a925]. Now you can answer or hang up any
voice call immediately (incoming or outgoing) with one key press only (you can define any key you want for it). You can customize
all device keys (if you want to). Tracker automatically determines your device and determines what keys are available. Moreover,
with each key you can have multiple actions. One for standard key press, second when the key is held (for 1 sec) and when you are in
Flip Closed mode (if your device supports it). You can customize some Tracker's behaviour selecting 'Settings' command on the
Tracker menu.
