Voice dialing ? How ?
2 replies · 3,797 views · Started 27 October 2007
Hello. I'm a new user of E90. I'm trying to enable voice dialing to some of my contacts but with no success. I'm from Greece and my contacts are written in greek. In the manual says "To listen to the voice tag assigned to the contact, select Options > Play voice tag." but i have no such option. Any ideas ?
Go contacts, select one contact to see details, then options, here you can find the play voice tag option.
To use voice command press and hold the button on the top right side of your e90.
You can double check your voice settings in: go menu, tools, voice comm., option her synthetiser should be tourned on.
Cheers!
swingerman wrote:Hi,
Cheers!
Voice settings are as you say. But when i go to contacts and select one and then choose options I don't have the "play voice tag" otion. Help please ?! 😮
