iSync and Leopard
7 replies · 3,419 views · Started 27 October 2007
Well, I upgraded to Leopard yesterday and found that the iSync plugin no longer works for me with my N95-3. Also, i've heard that Nokia's multimedia sync won't even open in Leopard. Has anybody had any success with iSync and 10.5?
I think.. more of the question would be how did you get a N95-3??
bchliu wrote:I think.. more of the question would be how did you get a N95-3??
Maybe farfrommovin is in America, where the N95-3 is for sale?
I'm disappointed to learn that the plug in isn't compatible with Leopard, as I plan on getting that very soon. Let's hope Apple releases an update ASAP!
I see from farfrommovin's same post on another forum that iSync on Leopard does work with the N95 - what a relief!
Sorry guys, false alarm. The N95-3 DOES sync with Nokia's plugin. I just deleted the pairing on both devices and set it up again and it worked right away. And yes, I'm in California where I can finally have a high speed N95 on this side of the pond 😊
I'd like to keep this thread going because no matter how many times i delete pairing, replace calendars on the first sync or (dare i say) repair disk permissions: nothing works.
Originally only events changed on the computer were syncing but now I have duplicates of everything (most likely due to calendar groups) any ideas?? thanks
Nokia MultiMedia Transfer 1.2 is out:
* Mac OS X 10.5 Leopard is now supported
* Improved Nokia Device Browser with folder view
* Ability to customise the transcoding of files in iTunes and iPhoto transfers
* Performance of iTunes and iPhoto transfers with a large number of files has been improved
* Many bug fixes and minor improvements
See more here: http://europe.nokia.com/A4423134
shanespencer wrote:I see from farfrommovin's same post on another forum that iSync on Leopard does work with the N95 - what a relief!
Yes, it does. I've had no problems at all.
