wifi
2 replies · 5,637 views · Started 28 October 2007
I am about to purchase a 6120c handset. I am bothered about the lack of wifi capability and wonder if there is any solution for that.
Is there any miniUSB to wifi converter, or a BT to wifi converter?
Does SDIO card should do the work?
Will be thankful for any help.
BR
Moshe
There's no way to add wifi to the 6120. Apart from the lack of hardware, there's nothing in the firmware to support it.
Hi all it is my first time on this Forum so I'd like to start by welcomming everyone!
So my question is : are you sure that there is no way to add wifi to 6120 phone ?
I found here :http://pdadb.net/index.php?m=specs&id=985 that this phone has SDIO slot so theoritically it could be possible to install wifi sd card in this phone.
robgreb you said that there was nothing in the firmware to support SD card. Did you mean that Operating System does not provide support for those cards ? Or there is no software capable to use them?
So if micro SD is not an option there are two other solutions that I have in mind 😉
First one is using some mini-usb wifi-adapter (I have no idea if there is such thing)
and the last one is using bluetooth / wifi bridge device ... (I have heard that Phone must have installed some additional software like Hiisi)
Best regards deemer.
