Playing .asx on N95
2 replies · 10,474 views · Started 29 October 2007
Is there any application to play Windows media streams (asx extensions) on N95. I'm trying to get better quality while streaming via Orb2.0
not really. the only way to do it is use orb to re-direct streams from your PC out over the web in another format. then you can login from your n95 an listen to them...all free of course.
