Is there any GPS software that you can record the route you drive through from point A to point B ? that's a very useful feature if you go camping and you go off the road.
GPS Record
Hi there,
try the Nokia Sports Tracker ( http://research.nokia.com/research/projects/SportsTracker/ ).
Cheers,
PM
Thanks, will that work even if you go off the road ?
PMitchell wrote:Hi there,try the Nokia Sports Tracker ( http://research.nokia.com/research/projects/SportsTracker/ ).
Cheers,
PM
yes. it doesn't matter on or off. you just have to export the file to google later to see it on a map.
I'll second Sports Tracker, it's a great app!
GordonShowers wrote:I'll second Sports Tracker, it's a great app!
yes it's great , it would be nice also if Nokia can export the file to be use on their Nokia maps too
