Connect 6290 to internet through LAN.
1 replies · 5,168 views · Started 29 October 2007
Is it possible to use my broadband connection with the phone; to connect the phone to the internet not through GSM but through my LAN connection over bluetooth?
I was thinking the same thing, will try it out and let you know. Not confident it will work as the phone will probably be set to use the network provider internet access, wish this phone had wifi like my N80 that broke 😞.
Cheers
Ant
