The E90 update arrives - 7.40.1.2
39 replies · 9,585 views · Started 30 October 2007
Like many others, I've on 1 hour 'refresh' on Nokia Software Update for what seems like weeks now. But the Nokia E90 update seems to have arrived and it's installing as I write this. Version number is 7.40.1.2 and I'll post comments and observations below as and when....
Arghh. Well, that was an anti-climax. For me, at least. The proto didn't like NSU and promptly died. 8-((
So it's over to you guys to supply any notable changes!
Meanwhile, I'm off to a Nokia Service Centre later in the week to try and resurrect my baby...
And my Nokia Software Updater (here in the UK) states that my old firmware is up to date!
As does the "Find the latest version" on the Nokia website. According to the Nokia website the latest version is: 07.24.0.3
NSU definitely doesn't seem to like my Windows 2000 work PC 😞
Fortunately it doesn't seem to have bricked the phone in the process so I'll try using XP when I get home....
I have an E90 from Singapore but changed the product code some time ago to UK Moca and the update is available through NSU even though the Nokia Software Availability web page states that it is not. The product code is 0533332.
NSU still states that I have the latest Firmware 07.24.0.3. But at least it installed an update of NSU itself.
AM DOWNLOADING THRU NSU 1.14
SLOW CONNECTION AS AM IN MEXICO, BUT DOWNLOADING OK, will update later.
Rgds
ok successfully downloaded and all data seems fine. It seems that you have to use NSU 1.4.14, it gave me a message saying unavavilable and tried again and it seems ok
Best rgds to all
I've got one question: does E90 have 3D accelerometer like N95 (it gives notification about the phone tilt)?
thanks in advance!
hasnt nokia added demand paging? oh well, dont look good for the n95-1 then, but then again, e90 dont need it as it has alot of RAM, hope n95-1 gets it tho
My UK Mocca E90, product code 0552464 still shows 07.24.0.3 as the latest firmware. (By both entering the product manually in Nokia UK's website and using the NSU software)?? Steve, is your product code different? Best Regards Nick
Seems to mee that I have a l,ot more free RAM about 135 Mb after reboot. Would that mean that Demand Paging is active just like in N95-8Gb?
This UK mocca product code works-0533332
Basically, as many have observed, the release of the update seems to be staggered, using the product code to differentiate the phone. If you are impatient you can simply set the product code to one that works and off you go.
Here are the steps gleaned from various postings, I had mine updated in less than 20 minutes altogether:
1: Make sure the latest Nokia Software Updater (NSU) software is installed
2: Make sure that you have backed up the phone memory using the "Memory" application (in the Tools folder). This is done from the Options menu, then select "Backup phone memory"
3: Download the NSS software, this will let you modify the product code. Get it from the bottom of this page: www . b-phreaks . co . uk / software.htm
4: Unzip, then install the program, accepting the default settings.
5: Connect the phone with the USB cable.
6: Run the NSS program, once it starts click on the Scan for new device icon (the last on int he toolbar). This will connect to the phone.
7: Then click on the "Phone Info" tab in NSS
8: Now click on the button which says Scan (under Actions, different from the previous one)
9: Once the phone is found, click on the Read button in the "Production Data Edit" box. The various fields should be filled in.
10: Now click on Enable outside the "Product Code" field
11: Select a valid code (see other posts) from this list: allaboutsymbian.com / archive / t-62338.html, I used the UK Mocha one, worked for me.
12: Enter this code into the "Product Code" field, then click on Write.
13: That's it, now just do an update using the NSU program.
I justed updated my software to version 7.40.1.2
However when I connect my phone to Nokia Device Status, it states that I am using to old software version 7.24.0.3
So I reconeected my phone to the Nokia Updater (NSU) and it states that my phone is up to date with software version 7.40.1.2. Strange that the Nokia Device Status program does not recognize that.
How can I find out exactly which version of the software is on my phone?
Is there a way to see that information directly on the phone?
Some answers:
See the My-Symbian thread for all the product codes - I've never had to do anything like that. http://my-symbian.com/forum/viewtopic.php?t=32774&postdays=0&postorder=asc&start=630
Try Device Status on the E90 itself - it reports the right (new) version. http://nds1.nokia.com/NOKIA_COM_1/Microsites/BetaLabs/applications/apps/devicestatus_1.1.86.sis
RAM - no, you're reading the wrong figure. The E90 now has 79MB free out of 109MB RAM total. With a 19MB ROM image, that makes 128MB, the full complement.
So no demand paging, then, but still oddles free compared to many S60 3rd Edition devices. And I've never managed to get the E90 down beyond about 40 to 50MB free 8-)
Anyone notice something odd with the characters on the qwerty keyboard?
For eg. "/" appears to type "\" and "," is typing "-"
Have i done something wrong during the update?
That suggest to me that you've installed an update for a different country's variant of the E90 with a slightly different keyboard layout.
On the UK keyboard, the "-" character is immediately to the right of the space bar, and the comma is directly above it.
The full layout of the raised bit of the keyboard on my UK E90 is
1/!, 2/", 3/�, 4/$, 5/%, 6/^, 7/&, 8/*, 9/(, 0/)
qwertyuiop
asdfghjkl ;/: '/@
zxcvbnm,./ [Shift]
[Chr] z/|, [/] [Spacebar] -/_, +/=, #/~ [Chr]
HTH
Julie
Unfortunately the bug in the call log. All mobile phone icons, also with fixed phones
Just updated (though the whole experience is quite worrying: the software update got to 2 mins to go then the phone turned off and then eventually NSU alerts you 'connection lost' but when you power on the phone, all is well and the new software is in place OK. You then have to cancel/abort NSU as if it wasn't successful. This happened when I upated to 7.24 originally too.). One minor point, Quickoffice seems to be 3.8.12 not 3.8.5 in this release.
Definitely not an update for the faint-hearted! NSU twice lost the connection to my E90 and I had to power it off twice - once by removing the battery. Restarted both phone and PC and got there in the end.
From my experiences with it I would also advise against running NSU on a computer running Vista unless you really can't get access to one running XP.
Is it just me, or will BlackBerry Connect no loner work after the update? This messes up my life!
Any way to fix it? Just get an X through the symbol at the top, no matter what I did, have reinstalled a bunch of times.
same here! I lost my BB service since the firmware update. Apparently its something to do with BB client software being tied to FW. Looks like Nokia got itself into another tangle.
... meanwhile, waiting for someone at RIM/Nokia to come up with a fix...
... and very sadly... theres no bb client actually for the latest firmware.
its a very very ugly situation nokia/bb throws there customers in because a firmware downgrade isnt possible anymore. hopefully they release a new client for the e90.
see also :
discussions.europe.nokia.com/discussions/board/message?board.id=communicators&message.id=11655
I read that a lot of updates fail or that the update is not for all product codes.
Would you take the risk to update it already or would it be better to wait some more weeks and to update then, because I don't like to start the product code etc. How about the warranty and so on then?
If your signature is up to date, it's probably a moot point. Wait and see what firmware you get on your E90 when you get it 😉 You may find that it comes with the new firmware pre-installed anyway.
Somebody has already posted to say that you'll invalidate your warranty if you change the product code.
Other than that, it depends what your priorities are. Don't update if you want Blackberry connect (there doesn't appear to be any support for it). Update if you will make heavy use the internal GPS or any of the other fixes.
Julie
