IrRemote beta
10 replies · 5,530 views · Started 31 October 2007
Hello,
I just downloaded the irRemote beta for S60v3 for the psiloc.com. It did not work:con? Did anybody already use it on the N80?
Wim
kontraband wrote:whats the problem??
The program starts but Im not sure whether my IR works. If I activate the ir through the Connect menu I can not start the program. If I use the program for my Sharp TV without IR activation it does not do anything.
Wim
I've managed to get it control an old sony TV. Can't find the specific codes for my newer appliances in the lirc folder so I need to try some others.
Burcrim wrote:I've managed to get it control an old sony TV. Can't find the specific codes for my newer appliances in the lirc folder so I need to try some others.
yeah, Im in a similar situation.... so hope the beta gets passed quick and they expand the products ! 😉
i downloaded it from their web site for my N80,
it installed ok, BUT when i click on it nothing starts or happens
am i doing something wrong
any help please
thank you
Yeah, that happened to me. I unistalled the two items it installed, reinstalled and restarted the phone. Then it worked fine.
here some help
h**p://shop.psiloc.com/pl/Support,1190,S60+Update+error
oh, and thanks for the advice on uninstalling
cheers Burcrim
ok it installed and when pressed it worked, BUT then it said you need to activate it so i went on line, and it said you have no credit
totally lost.
do i need to buy something from their site.
You can only activate for free if you have previously bought something from their website for the same phone. The free version will stop working in two weeks anyway.
