W950i Reseting after making "Fonts" folder in External drives "Resource" folder
1 replies · 4,349 views · Started 31 October 2007
W950i Reseting after making Fonts folder in External drives Resource folder
Here's the Scenario:
I wanted to install Some Additional Fonts in My Phone. I put my phone in "Fast Mode" and I created a Folder "Fonts" under the Resource Folder in the 4GB External memory. I wanted to Copy Some Windows TTF fonts to the folder and So I opened the Explorer. This is where I think the problem started. I felt like changing the Memory Name of the phone and I changed it to "WXYZ" from "ABCD" and I went into the Above mentioned folder ie Resource\Fonts and tried copying the fonts which failed with the message "The Path is Too Deep". And the memory was not recognized and I kept getting the message Please insert disk into the drive.
So what I did was I switched the phone to "Normal Mode", Disconnected (Here again the external Memory was available in the standard SE File Explorer view) the phone and tried rebooting the same. The phone started Booting and Showed the Walkman symbol for 2-3 seconds and the screen flickered and reseted itself. This is going on continuously. Update to latest firmware is not helping and since I can't boot the phone I can't see the Firmware Version and such information for the phone.
I tried removing the SIM hoping that it would show up the setup screen, but that doesn't work.
Could Someone suggest what can be done to set this issue right?
Also If someone can suggest a way to Format the internal memory, that would be of great help, as I feel that that can probably solve the issue.
