Just installed SDoubler 1.3 but it seemed to have move all the icons around and out of the folders (Tools, extra etc), has anyone else had this? I had 1.2 installed previously without this side-effect. Now I cannot exactly remember which icons should be where, any screenshots would be helpful.
SDoubler moved menu icons around!?!
I have had that happen to me a few times.
But not with sDoubler, I think. Maybe. Possibly. Dont know.
If you need the icons to be in same places (why), then look in the manual.
I haven't tried SDoubler but if it encrypts apps, aif files etc. then of course they disappear from Menu because Menu application cannot recognize them anymore as apps. Do they come back in their original places when you decrypt those apps?
I am also running sDoubler 1.3, but without having the problem you described. I have extermely cusomized folders and icons, and all stayed where they should be. However, now that you mention it, I also had this problem once, but quite some time ago, before I had sDoubler.... Can't remember what could have caused it.
BTW, sDoubler doesn't remove the aifs. It just modifies them (optionally). So they should always appear in the menu.
Yeah .. I have SDoubler 1.3 installed in my 7650 now and I don't have the problem that you mentioned ... I think I gonna stick with it now ... previously I use SDoubler 1.2 ... then convert to Stacker 2.05 ... Now convert back to SDoubler 1.3 ... the reason ... SDoubler can compress Application MIDP and Stacker cannot .... why does this happen ... can you clrify it HERA? 😃 😃
[quote="MaxiMuS"]Yeah .. I have SDoubler 1.3 installed in my 7650 now and I don't have the problem that you mentioned ... I think I gonna stick with it now ... previously I use SDoubler 1.2 ... then convert to Stacker 2.05 ... Now convert back to SDoubler 1.3 ... the reason ... SDoubler can compress Application MIDP and Stacker cannot .... why does this happen ... can you clrify it HERA? 😃 😃[/quote]
sDoubler doest compress java apps, because they are already compressed. what sDoubler does is compress the data it gathers, like high scores and players names and game options and settings. 😃
