Headset Issue
4 replies · 1,853 views · Started 31 October 2007
Does anyone else's headset controls not work?the sound comes through them but the controls on the headset don't seem to work. is this a common problem or just me?its not worked from day 1. thanks
my headset was a bit flaky... I took it apart and reconnected and its been fine since...
I see a lot of problems with the connection between the earplugs and the controls... try removing that or giving it a shove.
its shocking the amount of problems there actually are when you think of them all
