Hi, Does anyone know if TomTom mobile runs on the SE P1i.
And if so what version is needed.
TomTom for p1i
Yes TomTom is available for P1i and you should use the UIQ(3) version of the program. Remember that even though both (Nokia) S60v3 and UIQ3 are based on Symbian 9.1 the UI code is different so always use UIQ3 version applications on your P1i (older UIQ wont work either).
Does any one have the correct TomTom version UIQ(3) for sale as I'm having trouble locating it.
Thnx
I think you can get it from Tomtom.com directly. Although it says it supports only SE w950i it will work on your P1i. Just dont buy the program on the memory card since they are Micro SD and not M2 which you would require.
i used tom tom on my P910i, does the same version work on the p1i? if so please let me know how i go about installing it.
I have tried copying it to different folder but can not get it to work.
Help!!
Regards
