<b onMouseOver="window.status='I am a very bad boy everybody go to www dot warezhere dot com'">Just some ordinary text</b>
If you dont know what this post does......then look at the status pane on the bottom of your browser after you point the mouse over the ordinary text.
I havent come accros this kind of linking, but if I thought of it someone else might too!
Just to be sure!
<b onClick="self.location='http://nokia.warlocks.be'">OMG</b>
<b onMouseOver="self.location='http://nokia.warlocks.be'">OMG</b>
Seems like a serious bug in BB, great work MaleBuffy
Although I can't get it to work 😊
it doesnt like "." and ":" i think thats why I used dot instead of dot. Try it!
<b onMouseOver="windows.status='?'">really?</b>
Oh well 😉 I think it was an error allowing your post to go through 😉
This should work, but I disabled HTML in this post so I guess thats the problem. So if we disable HTML in general this could be avoided...together with all the fun linking images and all ..... 😞
I thought mere mortals had html disabled so they could only use bb code? Hell I thought we had html disabled too.
Ah yes, I forgot to turn off the disable HTML in this post, linking of images is done with the BBcode as well.
<i onMouseOver="window.open('http://nokia.warlocks.be'😉;">I think we should disable the HTML! (this is already dangerous)</i>
<i onMouseOver="self.location='http://nokia.warlocks.be'">This we really don't want :s</i>
