keep getting this message appearing when I'm trying to use the map loader
"Connection to the storage medium has been interrupted. Attach your storage medium and retry"
This happens when using both memory card reader and USB cable.
I get an error that says - An unexpected error occurred. Try again. Sorry for the inconvenience.
Only had the phone a few days and this is starting to bug me.
does no one know?
Try disabling your firewall / antivirus whilst downloading?
s.
its not that, it can download the files fine, its just when putting them onto the mem. card that it stops.
Hi there,
I had this problem when using a usb-hub. I recommend not to use one (if this is the case) or use another cardreader otherwise.
Regards,
PM
have tried another card reader and still getting the problem
To get mine working I had to remove the proxy settings from Internet Explorer to make the maps program download the maps. Shame that it is integrated with settings used by IE when I don't use it other than at work.
