Nokia Multimedia Transfer 1.2 Beta for Mac just got Leopard-compatible! It also adds an improved Nokia Device Browser with folder view and the ability to customise the transcoding of files in iTunes and iPhoto transfers.
The mac transfer utility is unfortunately not compatible with N81 😞
Strangly the old version 1.1 on Tiger worked fine with the N95 8GB, but didn't work with Leopard, the new version 1.2 works with Leopard but doesn't work with the N95 8GB.
Not a huge problem as plug in the N95 8GB via USB and iPhoto 08 will recognise it as a camera and offer to import your photos anyway.
Doesn't work with N95 8GB, what's the point?! SOOOOOO Frustating Nokia just refuses to accomodate mac users. As a die hard Apple and Nokia fan it's driving me nuts. They should dedicate a team to mac software and use this as a way to obliterate iphone competition even further. Grrrr. I sometimes wish I worked for both companies.
