I want to download word, excel, PDF and powerpoint documents onto my P990 from my PC. How do I do this?
how to download docs to 990
Connect your P990 with USB to your PC, Windows its going to recognize it as a Memory Device like flash drive. From there copy and paste what you want from your PC to your destination folder on P990.
Remember on P990 USB menu you should check Memory instep of PC Suite.
Thanks. I can download files onto the 990. After working on the files on the 990 (eg excel spreadsheet), I have to then save it over the version on my PC to update it. Is there a simpler way to sync the files between the 990 and the PC?
