product codes
3 replies · 1,523 views · Started 04 November 2007
hie guys am new in the group what does the term product code refer to thanks
the product code is the version of N95 you have, as much as to say, which company has installed its firmware on it... i.e. although both N95's your product code for a T-Mobile one will be different to an O2 one... as will a plum one from an other colour N95.
You can find your product code under the battery
thanks for your reply so what does it help then knowing the different product codes is there any use please
yeah, if you want to update your firmware to the latest release from Nokia, but your service provider hasnt signed it off you will not be able to use Nokia Software Updater to update the firmware...
So
You'd use another program to change the code to 'trick' NSU to update your firmware...
this would then give you a generic Nokia F/w version without any of the service providers add ins.
