SkyeQuiKey - Direct Key Contacts, Applications, Bookmarks and Other from Idle Screen! - save 30% from PDATopSoft.com
pdatopsoft.com/software/item.php?pid=12553
SkyeQuiKey - WHAT DOES IT DO?
# SkyeQuiKey is an 'instant key-and-find' application using Skyestream's quikFind technology
# Quickly find of Contacts, Applications, Bookmarks and Other Data on device
# SkyeQuiKey reduces key presses and provides a 'global search' on your phone to quickly find what you want
# Integrated seemlessly into the S60 user interface
# Predictive-text technology used to minimise required input when entering search criteria
# From phones idle screen, start typing and SkyeQuiKey will present a list menu of 'items' found matching the keystrokes
# Contacts: Instantly start a call or send a message (SMS, MMS or email)
# Contacts: Search for contacts by phone number (a feature not available in the built-in Contacts application
# Contacts: Optimized Contact discovery. Contacts will be searched for using name, surname, company and email address fields
# Quickly action a 'found' item. A single key-press will allow you to call, text or launch the item
# Instant search results: High speed search algorithm used to instantly find and display search results
# Configurable shortcuts: With a single click, compose an SMS, MMS, Email message or make a call
# Frequently used activities also listed in the SkyeQuiKey main menu, for example: new SMS, new MMS, new Email
LANGUAGES:
English, French, German, Spanish, Italian, Portuguese, Simple Chinese, Traditional Chinese
