Thanks all, some good feedback!
>>The Kaiser is more pocketable than the tall and incredibly heavy e90
It's not THAT much heavier, and I guess I don't think about tallness because I keep it in a belt case... (I've always done this etc, for any PDA)
>>, and while he harped on the build quality of tytn (which I don't think is that bad comparative to previous products of HTC (where the build characteristics
Oh, agreed. But the all-metal E90 will be still going strong in 10 years time when the mainly plastic TyTN II has been disabled after a drop onto the pavement. Possibly. 8-))
>>number of SERIOUS hardware issues found in the first generation nokias.
I mentioned the initial niggles (screen marks, mike noise) near the end. And what can I say, *my* E90 has been near perfect from day one, for the last 7 months.
>>There is also a real world price issue, with the E90 in some instances costing 50% more than the TYTN II. The question would be "are those five points difference worth the almost $300 USD price difference?" And finally (on the N.A side) there is an issue of lack of 3G on the E90.
Ah, yes, an E90 in the USA doesn't make sense. Do please bear in mind that I'm European though and that outside the USA, the E90 will work perfectly at 3.5G speeds. 8-) And pricing isn't that different over here, especially if you buy with contract etc.
>>Winmo 6 is not spectacular, and I absolutely hate Pocket Internet Explorer, but the S60 implementation on the E90 is not that brilliant, and it shows when loading third party programs on that internal screen. I believe it's close with a brand / OS preference, location, or monetary concerns really being the deciding vote.
Agreed. Especially for anyone in the USA.
>>I just found it odd that he really didn't say anything positive about the Kaiser, but the score was a lot closer than his disappointment let on.
The problem is that I did feel 'let down' by the Kaiser. It never stood out in ANY area and shouted 'Isn't this bit brilliant?' From screen to keyboard to WM6, it was all a bit average and predictable. Whereas the E90's wide screen, metal construction and app shortcut keys all impress just about everybody.
8-)
Steve
