Multimedia Factory usage on N95
2 replies · 4,142 views · Started 09 November 2007
:icon2: i am unable to send MMS using mutlimedia facoty with my N95 fone , on send i get " the connection to device failed an unknown error " i am able to to do all the other operations using PC suite and my mobile fone i.e sending text messages , contact updating , file transfer etc . is any body else having this problem ( i have clean installed pc suite and multimedia factory twice )
help any one any where / many thanks for reading 😉
i have pc suite , 6.84.10.4
multimedia factory 2
fone firmware V 12.0.013 /19-06-07
RM-159
Nokia N95 (43.04)
i have corrected the issue by deleting MMS in the device (N95) / now everything is working fine /
I have faced the same kind of issue with N73.I am using Nokia Multimedia factory to send MMS but get the error that Connection to the device has been lost and cannot send the MMS.My MMS settings are all correct.
Is there any way by which this can be fixed?I have tried all the ways to solve it.Any help would be great.
