I have a new n95 but i cant seem to be able to browse using it.
I think i can get a wifi signal through my bt hub because the phone is able to fing the signal and say it strong, but when i try to/press stsrt browsing nothing happens. if i am on menu > web > then select web it juss goes back to the previous screen . help
web broswer doesnt work on n95 HELP HELP
I've had the same problem. My brother helped me setup mine as he was more annoyed by it than me. Allow me to suggest a solution:
Goto Menu -> Tools -> Settings -> Connection -> Wireless LAN -> Options -> Advanced settings. You'll know you have the right screen as it'll pop up a "changing advanced settings is not recommended" message. Just say Yes to that, and change the settings so they match the following:
Automatic configuration: Disabled
Long retry limit: 4
Short retry limit: 7
RTS threshold: 2347
TX power level: 100 mW
Power saving: Disabled
Please note that excessive use of WLAN will make the phone quite warm. As far as I know, this is normal. Best of luck 😊
thanx. tried it no luck this time around.
i can search for pictures for instance and open them but i cant open websites. any suggestions
