I think......I have IE on my orange networked branded N80.
I have the version
V.4.0623.0.42
20.09.2006
RM-92
Nokia N80 (31.01)
However there is a v.5 which is out but using the NSU I can only get this...
Is there a way to get the firware v.5? and what differences and improvements are there to the v4 to v5?
help would be appreciated
thank you
dk206
Search the forums - if you want to unbrand your phone to a generic phone, there are plenty of posts.
Note, by doing so you are going against warranties, etc, so do so with caution!
I think the upgrade threads have to be the most read threads on here!
Go look there... everything you need from the numbers to what to do if it doesnt work! 😉
I have de-branded 2 Orange N80s ( Mine over 12 months ago and one I bought s/h for the missus.
You just need NSS software which is downloadable and then use product code 0529379
Then do a normal NSU update and it will be V5
mines currently v5.0719.0.2
If you need the software give me a shout.
