Has anyone tried syncing between Symbian 2nd edition and 3rd edition phones? I can sync to my PC with PC Suite, but I haven't figured out how to sync my two devices without the PC. I have a Nokia 6682 and N75. They both support syncML, I'm just not having any luck. Any suggestions? I use my 6682 at work (since it's older) then swap the sim card into the N75 for night and weekends. I would like to sync them in case I add a contact or calendar entry without having to go through the PC everytime. Thanks in advance.
Sync between 2nd edition and 3rd edition
Its not ideal (and over kill for you) but have a look at this:
http://www.allaboutsymbian.com/features/item/Who_needs_Outlook_Syncing_to_Mobicalnet.php
However I would caution you to be wary when doing multiple Syncs. Make sure you set the phone as the primary device so things dont get over written.
Great idea! I had heard about Mobical, just never thought about using it in that way. Thanks for the tip.
