Light Sabre: go iPhone-hunting on your N95!
16 replies · 5,327 views · Started 11 November 2007
I'm still filing this under 'Nokia was mad not to have released the inclinometer plug-in months ago', but.... Aha, someone's produced an app that finally uses the N95's built-in accelerometer to do something really, really useful, day to day. Yep, it's your very own light sabre. Run the app, press the d-pad button and challenge a new iPhone owner to a duel (via Ricky Cadden).
why is it that i can't open this app? its installed but when i click it, nothing happens!
Yes, the same happens to me. I get the light sabre icon appears but when clicking on it it just refreshes the menu screen and nothing...
What does it do exactly?
<SPLORF!> I hurt from laughing. Even the cat's laughing in our house. I started laughing even harder when I realised that Symbian developers have been working around the clock to find something really useful to do with that API and came up with... a light sabre. Utterly brilliant. 😃
Amazing! i can't wait to see more appz that make use of the accelometer!
installed it all and its working but i get no sounds , just a set of X Y co-ordanece
You'll have to pres center in order to make it work... Mine is a green sword... 😊)
at unregistered 😊
Read Steve's instructions carefully padewan - you are forgetting to press the d-pad button to activate your light sabre! Be sure to stand well back and may the force be with you...
- Andy B.
Unregistered wrote:at unregistered 😊
- Andy B.
wise one u are , may the force be with you 😊
I've installed the first bit bit when I install the Lightsaber application I get "Certificate error, contact the application supplier"
Where am I going wrong?
Unregistered wrote:I've installed the first bit bit when I install the Lightsaber application I get "Certificate error, contact the application supplier"
Hmm you might need to change your security settings in App Manager from Signed Only to All.
What other phones use the acceletometer? I was waitng for a while for this to come out for my 5500 since the guy published a video on youtube many months back, butthen I sold my 5500 because it still couldn't beat my 9300. Movig to the states soon and may upgrade then but the e90 doesn't have the function, not to sure about the US N95, so what other options do I have?
