Hi there, i've just got my Nokia E90, and it seems when i put it down on a table, if i press any corner of the keyboard, the opposite corner comes up. Hense its not flat. Is this a common problem or just my phone? Its the small bit of plastic by the camera which is not level.
Nokia E90 - case not flat?
Mine does the same 😡
I remember reading about this as a "uneven rubber feet" problem in earlier E90's
I have got one of the latest batch (10th oct onwards I think ) from o2 , and among the things that are wrong ,that I thought had been sorted out are
1 ) The rubber feet wobble thing
2) The Hissing noise at the beginning of some phone calls (not often though - maybe 1 in 10 calls ? )
3) The Screen gets marked by the keyboard
All of these are issues that I assumed were rectified during the period of unavailability - but seemingly not -unless o2 have flogged me one of the old ones
I have found a soloution for all the above - I simply chucked it in a drawer and bought an iPhone :tongue:
....... No , seriously (I have bought an iPhone , but that is a different story )
None of these problems are "huge" IMO , and I a think of them more as quirks than anything else - I am happy to live with them
( there is one other point , but I will start a new thread about that)
I had that with my E90, but I just took a metal nail file to the feet that were to high and problem solved.
it's indeed a pitty that it is unstable, a good point though is that when you open up the E90 it sits on the hinges and doesnt wobble
