Nokia N73 switching off
5 replies · 9,368 views · Started 12 November 2007
[FONT="Book Antiqua"]I have had the N73 for the last couple of months working ok. It has version 4 of the software. Last week it started to switch itself off for no reason when in standby. Has anyone else had this problem? What is the resolution?? :redface:[/FONT]
my n73 is nearly 8 months old. (v3.0638.....) and i'm also facing the same problem for the last few months.
anyone any idea??
Hello All:
I am facing a similar issue with my N73. Have you guys found any solution or the cause of the problem?
Thanks,
Bondbhai
I had the same problem a few months ago, which eventually got worse and wouldn't manage even a few minutes of uptime.
Soft resets and hard resets did nothing
I even tried a reinstall of the firmware which made no difference, in the end I had it sent off for repair, and recieved a new one, so it must have been quite critical.
Phil
I had the same problem and was told by t-mobile that it was a 'power down' problem, apparently it is common on nokia phones. They didn't query it just changed the phone.
I have had the same problem on my wifes phone solved it by cleaning the battery contact and updating the phone software
