better than 1- touch
2 replies · 1,901 views · Started 12 November 2007
have converted from a treo 650 and i really miss the rapid dial that the treo gives you the 1-touch app is like this but only gives you 9 rapid dials :frown:
can anyone point me in the direction of a 3rd party app that gives you more than these 9 rapid down keys please
thanks
ilan1966 wrote:have converted from a treo 650 and i really miss the rapid dial that the treo gives you the 1-touch app is like this but only gives you 9 rapid dials :frown:
thanks
You can use the voice prompt for every contact in your phone book. You don't have to enter voice tags for each contact like other phones and instead just read the name as it appears in your phone book and it will find, repeat and dial the number for you. With some practice it's pretty handy and better than the traditional speed dial using the keys.
jeremyhelling wrote:You can use the voice prompt for every contact in your phone book. You don't have to enter voice tags for each contact like other phones and instead just read the name as it appears in your phone book and it will find, repeat and dial the number for you. With some practice it's pretty handy and better than the traditional speed dial using the keys.
Tends to work better on a BT headset than direct to phone.
Doubtless there are fast-dial apps, but the voice-dial is extremely good - if not always necessarily convenient ... always tends to freak folk out when you randomly call names out.
