SMS Writing
2 replies · 2,767 views · Started 13 November 2007
Before my firmware upgrade, when I pressed down while a word was selected, it would cycle through alternative words.
Now, however, when I press down it deselects the word and goes to the right...
How or what can I change to revert it to the old way?
Mike
What are you pressing?
[SIZE="4"]*[/SIZE] cycles through available options with each press.
Holding it down picks the next available word then brings up the symbol chooser.
Basically pressing down on the joystick used to cycle words as well as *.
Now, however, pressing down on the joystick deselects the word.
