Just letting you all know that if you got to m.vtap.com, you can view all youtube videos. I still don't know how they do it but it works.:icon14:
View all Youtube,yahoo, and more on your N95.
real player tries to play them and fails after a short time.
So maybe its not "all" ??
Wahey, I signed up on their site to let them know I'm an s60 user, after I saw vtap mentioned over at scobleizer.com.
They used to have a form you could fill in to let them know you had a series60 device or something else that that vtap didn't support. I filled it in with the hope of there being a s60 client but the form is now gone and this may be the final solution 😞
Tried vtap the other day on some youtube videos that I had previously tried to convert and download using vixy.net (and failed), seems to work ok so far, not used it enough to test the reliability and availability of the service though.
I work for veveo who provide the vTap service.
Seki - whos the service provider? May be it doens't support streaming vidoes (RTSP). If you are trying this in WLAN, your WLAN router should do RTSP NATing properly.
lightbulb - Sorry - We haven't yet starting sending our email/notifications to the users who have registered with us, we just wanted to make sure it work OK before we do that. Hope m(dot)vtap(dot)com works for you.
pachi - thanks for your comments, please send us your feedback on how we can make it better, we also play vidoes from google,dailymotion,myspace and other sites. If you find an Internet Site that's not available in our index, please let us know.
seki wrote:real player tries to play them and fails after a short time.So maybe its not "all" ??
prob cause you have to put your access point in RP.
tvishy98 wrote:I work for veveo who provide the vTap service.Seki - whos the service provider? May be it doens't support streaming vidoes (RTSP). If you are trying this in WLAN, your WLAN router should do RTSP NATing properly.
what you guys did is create the tru bread and butter.
tvishy98 wrote:lightbulb - Sorry - We haven't yet starting sending our email/notifications to the users who have registered with us, we just wanted to make sure it work OK before we do that. Hope m(dot)vtap(dot)com works for you.
Thanks for coming to AAS and posting!
Don't worry about the emails, I wasn't having a go, I got my hopes up that there might be a dedicated client for Symbian phones but the web based service will do 😊
It would be great if you do have plans to create a Symbian based client though :icon14:
Just tried this over WLan and works great 😊
Seki,
It is possibly that your Real Player is set to stream from a low bandwidth connection, mine was.
If you change it in Real Player settings this works well!
Cheers,
s.
all i can say is this video site is awesome!! i dont know how it works, but its great, has all the videos, and the quality is f*$king good! better than mobile youtube for sure. and it pulls videos from all the video sites, not just youtube.
lightbulb wrote:Thanks for coming to AAS and posting!Don't worry about the emails, I wasn't having a go, I got my hopes up that there might be a dedicated client for Symbian phones but the web based service will do 😊
Thanks, in-fact we have a J2ME version in beta stage - we support incremental character based search in that client - that user experience is much better and the player is embedded with in the client. I can share if you would like to beta test it - please PM me. Thanks again - Please send us your feedback.
Great news! I liked the look of Windows Mobile/Pocket PC client and was hoping for something similar. I look forward to trying out the beta client, PM sent!
i yheard tinytube.com or .net was a good one for mobiles
sturgeon wrote:Seki,It is possibly that your Real Player is set to stream from a low bandwidth connection, mine was.
Cheers,
s.
Hi there.. I've got the same problem as seki and its quite annoying! Which settings do u change in real player?
This site looks good so im hoping for the best 😊
jinx405 wrote:Hi there.. I've got the same problem as seki and its quite annoying! Which settings do u change in real player?This site looks good so im hoping for the best 😊
it works!!! at first when i changed my access point to my wifi, it still didnt work... and when i turned proxy servers off, it worked! so its all good 😃
amazing stuff as well... being able to access youtube videos from your mobile 😊
Note the real player settings should be set correct for the video to play properly.
Send your feedback/comments to [email][email protected][/email]
tvishy98
Do you know if there will ever be a way to save the videos to a microSD or lets say a 8gb HD?That would be awesome to be able to save the videos and not just bookmark them.TIA
hellscream wrote:tvishy98Do you know if there will ever be a way to save the videos to a microSD or lets say a 8gb HD?That would be awesome to be able to save the videos and not just bookmark them.TIA
We will look into this. Happy that you are enjoying m.vtap.com, please send us your comments at [email][email protected][/email]
i saw this on other forums.. hopes this could help.... http://www.ipmart-forum.com//forum/thread/208689/
