I'm having a problem and it's very annoying. When your using the 7650 keypad and somebody calls up, you answer the phone, but if you close the keypad it gives them a busy tone and when you do answer and want to close the keypad it hangs up on them aswell. This is especially annoying when you are using the handsfree kit and u just want to put the 7650 in your pocket but u gotta keep it open. Is there a solution for this? Thanks! 😃
7650 hangs up when you close the keypad
HI!..
i was thinking about the same problem...
Just if i want to call someone that is not on my contacts...
i open the key pad.. write the number and then i press the CALL key...
then i want to close the keypad because i don�t need it anymore and is more confortable to talk with out the keypad opened.. so..
if i do that i cancel the call when i close the keypad...
I know that if i mark the numbers then close the keypad, and then
i make the call with the options menu CALL... i can do that..
but is sad that the nice CALL KEY on the keypad will never be used :cry:
So.. somebody have to make an app option (like the lock or unlock keypad), and add the HANG UP or NOT the call when we close the keypad... that will be the most DOWNLOADED app on this forum 😃
i am sure of that 😃
well.. i�ll keep wating that...
please don�t tell me that v.4.39 Firmware came with that option? 😮
nobody mention it that yet..
cya!
Alejandro
True! its a bit annoying.
App needed. Anyone?
PsiLOC & extended Profiles???
Does Anybody know if updating the firmware fixes this problem? Because I'm currently still in v3.16. tnx 😃
The Nokia sliding keypad/cover concept is similar to that of the flip on flip phones. It's been there ever since the 88xx series and it's part of the design. You just have to get used to answer calls by sliding it open and hang-up by closing it.
I preffer to use the slide open only if i need the keypad... for text input or to type numbers that are not on contacts...
The size of phone don�t need to be so big when you are just talking 😃
By now i am opening the keypad.. i type the number then i close the keypad and then i make the call with option call...
In that way i keep the keypad close and i can talk 😃
BTW!.. i know that SoftKeyPad App can help to this... nice app... but
i want to type numbers and letters with the keypad... it�s faster...
Anyway...
cya!
Alejandro
But the main problem is when somebody calls you and you already got ur keypad open. lets just say for example your playing a game and then somebody calls you, u can't just close the keypad, coz u'll hang up on the person, u gotta keep it open. So u gotz ta keep it open. 😉
Also with the previous statement that it's just takes getting use to; flip phones like the Ericsson T20s has an option of not hanging up when the flip is closed. And when you have a handsfree attached, the flip can be closed. Thanks anyway 😃
Hope somebody does come up with a program like AEFOX said, or maybe a fix for it. Ciao
When you are on a conversation, and you want to close the phone, you press the left softkey for about 2seconds and then you can close the phone. The converstaion will not be terminated.
By the way, no 3rd app needed. 😉
Thanks Kobe works like a charm! Your cool dude! Peace out! 😃
yep the trick kobe mentioned was documented in the user manual if i'm not mistaken .. 😊
[quote="mikeeeee"]yep the trick kobe mentioned was documented in the user manual if i'm not mistaken .. 😊[/quote]
Yep. It's right there alright.
HEY!...
Many thanks! ... 😃
that's happend when we don't read the manual :roll:
Thanks a lot!
i knew that NOKIA don't make such a mistake on develop a
product like 7650 😃
hehe! i love my 7650 😃
cya!
Alejandro
Why don't you register. 😉
Yeh why dont you register man.This was posted from my 7650 on the new layout allaboutsymbian wapsite.
Another way is to dial the number from the keypad, close it before making the call, then Options > Call
