Abbreviated dial to conf bridge with pin
1 replies · 2,228 views · Started 15 November 2007
I am looking for software that runs on S60 on my Nokia E50 that would allow me to dial a PABX number and then connect to a conference by specifing a pincode.
Is there some software that would allow me to pre-enter the number and pin (after a pause) so that this can be done with just one key press or a fewer key press than the whole sequence and waits.
Got the answer myself thanks to pocketuk.com
Simply add a pause between the access number and the international number you wish to dial:
e.g. You want to call Mum in Australia.
So, you create a new entry called 'Mum' in your phone-book on your mobile and then when entering the number:
1. Enter the just-dial or just-dial card access number i.e. 0870 794 0000
2. Enter a 'pause'. This is done as follows depending on your brand of mobile
Nokia Phones: A 'p' should appear after * has been pressed 3 times: i.e. 0870 794 0000 (*** will show a 'p'😉
Siemens/Panasonic Phones: A '+' should appear after 0 has been pressed and held.
Motorola / Ericsson Phones / Sony: A 'p' should appear after * has been pressed and held.
3. Now enter your international destination number in full including 00 and press save.
That's it - next time you want to call 'Mum' using just-dial simply find mum in your memory and press call!
For definitive instructions please review your mobile phone instruction manual or contact your phone manufacturer.
