Programming your smartphone: Mobile Python
9 replies · 6,423 views · Started 15 November 2007
As something of a dabbler in PyS60, Nokia's open source port of the Python programming language to S60, I was excited to see the arrival of a proper book on the subject. "Mobile Python" takes a tutorial approach, leading you from the ubiquitous 'Hello World' right through to phone-controlled robotics and multi-player online games. It's a heady and sometimes uneven ride, but Mobile Python does manage to get across a lot of information while simultaneously firing the imagination of anyone who ever wanted to write an application for their S60 phone.
This book looks very interesting and I will probably buy it, but I was wondering if someone familiar with PyS60 knew if it has a module to aid in using the accelerometer for an appication.
Does anyone know if it's actually possible to develop/code directly on a nokia S60 phone? Rather writing and compiling on a desktop PC.
Using a fold out bluetooth keyboard, and your phone, can you program on the go?
there are a few packages available for PocketPC development on the device itself, it would be great if there was something like this on the nokia's.
You are asking for AccelerometerPlugin for PyS60 ?
Nokia has published the sensor module for using accelerometer from Python since 16 October 2007 (before the buzz about accelerators in N95 !) but it works actually with the following models : N82 , 5500 , N95 8GB , N93i 20.0.084 (XYZ axes)
N95 classic (only with X and only 4 values : right , left , top , bottom) like RotateMe from Samir
For full support for this one you have to use AcceleratorPlugin from NRC plus the aXYZ module (that I have developped since 13 November 2007 (before you wrote this article 😊 More than 70 downloading in 3 days !
You can download it at sourceforge search about pyed or search discussion about aXYZ on the Python Forum Nokia DiBO
You can ie use your N95 for making Lightsaber in PyS60 and look at Cube example
at the DiBo
Sorry I can post links because I haven't got enough posts (10) 😞
Cyke64
Yes, I've written quite a bit of Python on my N93, you just need a good editor, such as EasyEdit, and a copy of the API doc in a useful format (mobipocket for example). As Steve said, Python might be quite intimidating at first for people from a C/Basic/OPL) background, and I found the best way was to start from a working example and tweak it bit by bit. The ease of internet connectivity alone pays its bus fare - http post/get is simple, for example, so if you have a monster server sitting at home you can use it for beefy processing effort, bulk storage and serving up files in convenient formats, etc.
BTW the callback to detect the auto-rotation of the screen on the N93 when you do the old Rubik's Cube maneouvre doesn't seem to work, you have to poll for it instead.
Unregistered wrote:Yes, I've written quite a bit of Python on my N93, you just need a good editor, such as EasyEdit, and a copy of the API doc in a useful format (mobipocket for example). As Steve said, Python might be quite intimidating at first for people from a C/Basic/OPL) background, and I found the best way was to start from a working example and tweak it bit by bit. The ease of internet connectivity alone pays its bus fare - http post/get is simple, for example, so if you have a monster server sitting at home you can use it for beefy processing effort, bulk storage and serving up files in convenient formats, etc.
What do you mean by poll it ?
Cyke64
@cyke64
By 'poll' I mean check the 'size' method of your 'canvas' to see if it's (320,240) or (240,320). This is fine if you're constantly refreshing the screen, like Nokia do in their 'ball' example.
I did notice some other sizes but I think this is do do with a delay between re-orienting the screen and switching (back) to 'full screen' mode, which is a python VM problem and not visually noticeable.
