With my N95 with latest firmware I'm unable to delete a Device Management setting. Each time I try, I'm getting "system error".
Is there a way to directly change system settings via some files on the file system or some kind of registry in the phone?
do you mean a Device server profile??
kontraband wrote:do you mean a Device server profile??
yes. I'm able to add a profile but not delete it. I just get a System error. Really weird.
I though that the settings might be located somewhere on the phone so that I can delete it manually outside the phone
gemal wrote:yes. I'm able to add a profile but not delete it. I just get a System error. Really weird.I though that the settings might be located somewhere on the phone so that I can delete it manually outside the phone
did you populate it with true data or did you just 'try' it out?
You may need to connect to the profile to delete it if its true data, otherwise delete the information you have put in bit by bit and see if it will let you cancell it?? Not had the problem myself.. so guessing.
