hi!...i have a problem with my N80....phone stopes sometimes...!..and ...to use it again...i have to turn the phone on again... does anyone know what i can do about that problem?.... thx in return....:frown:
N80 stop problem
Sounds like you might need to update the firmware. If you type *#0000# on your keypad it'll pop up a bunch of numbers.
The top line tells you your firmware version. The most current version as of typing this message is V5.0719.0.2 - if yours is lower than that, then you can update by downloading the nokia software updater. (NSU) from their website.
V5 is pretty stable, rarely crashes so badly that you need to reboot.
yes V.5 is v v v v very good indeed most stable
i doubt they'll put out a new firmware this is really impressive
makes the n80 a totally different mobile to when it first came out! :icon14:
well the problem is i have this firmware update...i knew this is way better then other ones..but still i get this silly rebooting problem...any ideea's? thx :con?
DaniN80 wrote:well the problem is i have this firmware update...i knew this is way better then other ones..but still i get this silly rebooting problem...any ideea's? thx :con?
Is possible that ur battery is dying?
Sometimes a dying battery will cause the phone to crash as it discharges irregularly.
Also check the sim card is clean (clean it by rubbing a rubber on the sim cards metal contacts!)
