phone memory full
2 replies · 2,508 views · Started 17 November 2007
hi,
thanks for all your useful hints.
now i keep getting a warning that phone memory is full and i need to delete items.i have tried to do this on the phone and pc suite without success.
any advice?
thanks as usual
sam
Hello Sam,
I've had similar problem before. My E90's internal memory started to fill up with invisible files. The why I still don't know, but I solved the problem.
Simply back up you data to the mem card, reset your phone and restore.
If you want to have all your apps reinstalled after restore put all your unzipped install files in a dir on the mem card. The phone will try to install them.
With this reset I freed up around 80 MB!!!
Cheers,
Do you have emails sync to your e90? If you have, then there is a high possibility that the emails choked up your entire phone memory and the solution is to move all emails to your memory card.
