Is there any Navigation software that can use the internal gps of the N95 yet? I hear that TomTom can't at the moment, can any others?
any navigation software besides nokias that can use the internal gps?
they all do.. except TomTom which doesnt... yet.. AFAIK
kontraband wrote:they all do.. except TomTom which doesnt... yet.. AFAIK
please define "all".
The only ones I know of are route66 (which i use right now)
nudda wrote:please define "all".The only ones I know of are route66 (which i use right now)
Copilot
Route66
Navicore
Navigon
check the linnk ut666 posted... it tells you that in the first instance.
I've not tried the others, can only refer to Co-Pilot which uses the internal GPS receiver.
After a few months using it, I've now bought TomTom and would rather use that + an external gps device, than Co-Pilot. ( I used TomTom on a Nokia 6680 so knew what it was like, plus already had an external gps device anyway )
Not impressed with Co-Pilot.
