Desperately looking for some type of word processor or text editor for the E90 that has a PRINT function! Surely not too much to ask? I need to be able to print invoices at client's premises. I have ordered the HP Deskjet 460wbt printer. I did this before even thinking about whether or nor there was an E90 app that would print.
Thanks!
Only the advice... check on software section of this site, if any of dedicated to word processing software can handle that!
Thanks, but I have searched everywhere. The only solution seems to be some type of subscription model at cortado.com which looks very convoluted. All I want is a text app for the E90 that will PRINT.
Please anyone? Desperate here.
Hello aZooZa,
Here is one solution:
The web app is able to print. So you have to save your text file or doc as html, and open in browser then print.
Sounds great, but you need an app to save as html. I have MobyExplorer wich can do that, but it's not free.
I am sure that you can find other free file brosers that can save as html or maybe rename would be enough.
Cheers,
Many thanks swingerman! I'm playing around with that idea now. Much appreciated.
