I have done my best but i didnt get it!!! are the items listed (nk7650+PCSuite+wXPpro+BTooth) compatible???
Please answer me!!
THANKS!!!! 😃
nokia 7650 + PCSuite + WinXP(PRO ed.) + BlueTooth
Tekbreak,
This is a huge topic that's been discussed a lot on here over the last few months. There have been so many suggestions and ideas and possible fixes posted that you'd be a lot better off using the 'Search' facility to look for information to help you. There must be at least ten threads that have discussed this in the past - one of them will probably give you the info you need.
Nokia's official line is that PC Suite is not compatible with XP, but many people here have used the two together successfully. It seems to be more to do with the BT device you have and the drivers that go with it.
HI!...
Yep.. you need to search on many topics before
that are talking about this..
But just for your information...
i have... PC Suite + WinXPPro + Noka7650 (fw 3.16) + Bluetooth (Belkin USB BT Adapter) ...
All working together without any trouble...
i can do anything that all the software and hardware can do.
and i am very happy for that 😃
cya!
Alejandro
Hi, could you please mail me ? i have the same adaptor, the same OS but can't get it to work.. want to know what you exactly did to get it working..
my e-mail : [email protected]
Thanx in advance!!
