Msn
4 replies · 2,491 views · Started 18 November 2007
Hi guys,
i just bought an N95 on 3, i am now having problems accessing msn messenger when at home i could access it fine at a mates house yesterday, im trying to use the 3 mms connection and have a full signal including the 3G icon,
it just hangs on verifying username and password
any help would be appreciated
shadow123 wrote:Hi guys,
which program you using ?
I dont know 3 but shouldnt you be using the standard access point not MMS for anything other than picture messages?
your using the wrong connection
you should be using the 3 connection 3 mms is for picture messaging
Thanks using the 3 connection sorted it. i appreciate the fast responses aswell
the only other problem i have is that when i try and use skype it asks me to uprgade it and then says web operation failed.
any help is appreciated.
Guys
