Question is in the header, can I turn the light off - I can't see what it does, it's not bright enough to actually light anything and just adds to battery drain. Is there any way to turn it off.
thx
thx
The only known way to do this is to take a scalpel to the circuitry on the phone. If this idea doesn't strike fear into your heart then you can look here:
www.geekzone.co.nz/paradoxsm/3029
I have done this myself and it was pretty straightforward.
Thanks mate, looks and sounds a bit scary that one, but cheers for the advice.
You could always put some black electrical tape over it. 😉
