hi..i just got my hand to a new n73me.
the prob is the phone sometimes freez during sms.😡 .the keypad seems not to respond for about 3-4 sec..no other app are running togther..can u all give an advice.thx:con?
and i hv updated firmware..
Check that in your message options that your messages aren't being stored on the memory card, it does take a bit longer to access and store your messages on there, if you swap it back to using the phone memory, you'll find it quickens up.
the msgs are all stored in phone memory.nvr put it in memory card..:con?
nokia got something on their website called 'sms accelerator'
description:http://www.nokia.com.au/A4520888
dunno what it does, but since its being promoted by nokia, must be of some use.
