POP/SMPTP ports on N70
4 replies · 2,703 views · Started 21 November 2007
using the built in e-mail client in N70, is there any way to change the POP3/SMPTP ports?
I've tried to access my yahoo account, but failed as yahoo requires SMTP port 995 and POP3 port 465 (for SSL) 😡
Any help are greatly appreciated.
Thanks!
/Carl
It is possible, however you need to have the POP3 option activated in your Yahoo mail. Select the mailbox which you have defined then go to Options -> Edit -> Connection settings -> Incoming/Outgoing mail. Inside of those options there is a field in which you can edit the port number.
ratza wrote:It is possible, however you need to have the POP3 option activated in your Yahoo mail. Select the mailbox which you have defined then go to Options -> Edit -> Connection settings -> Incoming/Outgoing mail. Inside of those options there is a field in which you can edit the port number.
I can't find the settings that way. I've tried every possible menu option, but it just aint there. I have the latest firmware according to Nokia Updater, so what am i doing wrong? 😮
Thanks again!
Messages -> Options -> Settings -> Email -> highlight the account and then the path written above.
