Tom Tom SD card E62
2 replies · 2,494 views · Started 22 November 2007
I can't seem to find my GPS receiver, Wayfinder, and I was thinking that if I need a new one I would try the TomTom SD card nav system. Is it just plug and play or do also need a separate GPS receiver lto go with it. It looks like its about 89 pounds or so. If its just the card is sounds like a good way to go.
Thanks,
Bobby
Thank you. GPS antenna meaning GPS receiver I assume. I am still trying to find the one I misplaced.
Thanks,
Bobby
