Hey ...
I'm sure I recall ages ago Steve wrote about a great website to manage all your podcasts in one place, that whilst not actually linked to the Podcaster application worked very well with it.
I can't for the life of me remember what it was called though, or find it through a search of AAS. Anyone recall the site?
Paul 😊
Not sure if it's the same one but you could try podango (with the www at the front and .com at the back).
Melodeo is pretty good, i had it pre-installed on my N73, but the only links on the site at the mo are to American phone companies....still trying to work out a link for my 3UK N95.....
http://zeus.melodeo.net/mc/oem
This site has the downloads for melodeo, but you have to go there from your phone.....as it is downloads DO files (i didn't recognise file type) but phone did.
I chose Nokia HI-Res version.
You register at Melodeo.com and you manage what podcasts you want and then refresh from phone....
Best thing for me is that you don't have to download the podcasts, melodeo will let you stream, which is great when you have a data package, you can of course download them to listen to it later....
Ah, I think I gave duff info - wrong interpretation of "manage your podcasts". I took it as in manage the ones you've created, rather than the ones you want to listen to on a regular basis. Soz.
