Updated: Appman from SymbianWare
0 replies · 5,205 views · Started 23 January 2003
It's now available in English and German, it also includes some small bugfixes ( no more crashing when using taskswitcher when appman dialog is open, and you now can launch appman from extra's) and some minor improvements in logic.Handango link.
Full desc:
Get the most from your device with the Application Manager from Symbianware!
AppMan provides highly important information about programs and processes running on your computer and highly increases the performance and usability of your Nokia 92xx Communicator!
You can quickly see the status of the programs that are running and end or kill the programs that don't respond or cannot be ended with the help of Apps list. Define hotkeys to run your favourite applications and documents, switch between active applications with Windows style switcher (like Alt-Tab), close all apps, compact memory and much, much more...
Changings in version 1.03:
AppMan is available in English and German now
Some small bugs fixed (now AppMan can be started from Extras if it was unloaded before, task switcher doesn't crash when trying to switch task while displaying AppMan dialog)
Minor improvements in logic
Before updating AppMan to newer version, please unload it first (pop up AppMan dialog and then select 'Unload AppMan' command on the Tools menu)!
For more information about our products for Nokia 92xx Communicator and Nokia 7650 Smartphone please visit our homepages with SmartAppz.de and Symbianware.com!
