New firmware is avaiable 😉
What language is that for?
Polish.
saj0n1 wrote:What language is that for?
its out for EURO 1 product code also
Hi everyone,
Does anyone of it is possible to de-brand my phone with this?
gavinlew wrote:Polish.
evo6: try change product code with newest NSS and here you go. You can debrand 😉 Good luck!
I checked few product codes on this page:
http://europe.nokia.com/link?cid=EDITORIAL_528996
and looks that all not branded phones can update to newest.
I dont know what with branded - i dont have product codes.
So if you want debrand you can product code from this list:
http://www.allaboutsymbian.com/forum/showpost.php?p=345879&postcount=28
download newest NSS and everything should be OK 😊
Good luck!
firmware update succesfull.
product code change also succesfull.
Anyone else noticed that the Multimedia key now does nothing (other than flash the screen for a second 😉 )
Uridium: on my EURO3 version multimedia key works fine after upgrade.
Uridium wrote:Anyone else noticed that the Multimedia key now does nothing (other than flash the screen for a second 😉 )
is the camera better now?
Someone said it wasnt as good as the normal N95 phone..
Since installing V11 I can no longer access Google Maps. It's shown but I just can't open it. Anyone else having this problem?
uninstall google maps and reinstall.
I uninstalled all the applications after firmware update.
