Symbian's Latest Product, The Rubik's Mini-Cube
6 replies · 2,756 views · Started 23 November 2007
We're called All About Symbian for a reason... never let it be said that we don't review everything that has Symbian written on the side of it - last month's Smartphone's Show gave me the best product from Symbian in a long time. Read on for Ewan's video review of this must have item.
does it have string so i can tether it to my phone? xD
Don't be so silly, of course it doesn't.
You pair it through Bluetooth.
stuclark wrote:Unfortunately I broke my mini-cube. Do you think I can get it fixed under warranty?
Depends if you opened it to try and fix it yourself. Also so if you have the US 3G band version it does not have an international warranty.
If you use hot water / steam you can hack it (remove labels, replace in 'correct' position) so it looks like its not broken.
p.s. to get it to install you need to set your clock to before 1985, its a retro thing - something to do with certificates.
