I found the latest version (V1.3) of the lightsaber app, but my N95 tells me its not a supported file (.sisx). V1.2 gives me the same problems, yet V1.0 installs fine.
Can anybody help me? Does it need signing, even though my phone settings allow unsigned files? HELP!!!!!
Ive has the same problem with the N95 8 gig. Just doesnt want to install. Has anyone got it going on the new N95 8 gig?
Just upgraded firmware to v20, still wont work 😞
..... :listen: have you installed N95AccelerometerPlugin.sis first ?
evilweasel wrote:..... :listen: have you installed N95AccelerometerPlugin.sis first ?
Which, incidentally, is installed when you install the disturbingly compelling (in a sit and play with it for 10 minutes at a time kinda way) "moving ball" demo...
And I still want some kind of ball rolling maze game (or some kind of katamri damancy clone, or super monkey ball or anything else with a rolling ball...). Somebody make one. Now. (Please)
davecozens wrote:Which, incidentally, is installed when you install the disturbingly compelling (in a sit and play with it for 10 minutes at a time kinda way) "moving ball" demo...And I still want some kind of ball rolling maze game (or some kind of katamri damancy clone, or super monkey ball or anything else with a rolling ball...). Somebody make one. Now. (Please)
Yeah, someone totally should! There was one but that used the camera to detect movements so was far less accurate; and in any case I never got it to work 😊
The beauty of the "idly rolling something about" genre, as I shall now refer to it, is that these games tend to be peaceful, distracting games rather than the mental race/hurt/kill games we tend to drown in.
Plus without having to press the tiny keys I won't keep pressing the damned media key with my fat fingers. Grrrrr!
The N95 8 gig just wont install lightsabre. The plugin installed very easily.
Yeah, installed the accelerometer thingy, had to for v1 to work
Yay, got it to work, scoured google and downloaded about 5 different versions till 1 worked. Sorry guys, can't remember which site had the working version, but give it a try
I installed v1.5 on my N95 8GB.
It starts fine but I just get a green flashing screen with no sound or other sign of life.
Am I doing something wrong?
Ian
ichilton wrote:Hi,I installed v1.5 on my N95 8GB.
Do you have the accelerometer installed on your phone?
Also, it, lightsabre, has to be installed to your phone and NOT YOUR MEMORY CARD.
After you change settings, you have to press the left soft key again and select "light sabre" to initialize those changes and exit out of the options menu.
The accelerometer DLL is on there and the moving ball example and RotateMe work fine.
Lightsaber is on the phone memory too.
Ian
okay so it should work fine then, just remember that after you change settings to hit the left soft key again and select "lightsaber" to invoke those changes.
The program really doesn't do much other than flicker the colour on the screen and make the "swoosh" noises of a lightsaber when you swing the phone and randomly put in "hit" sounds.
Let me know if it works.
