Can someone suggest software to convert video files (any format) to 3GP of which the output is compatible with Motorola L7? Thanks in advance!
Video to 3GP format!
I understand your problem, But I use a great =http://www spamming service provider when I need to make lot of copy of any particular CD or DVD and it works very well for me. you can get lot of copy of your DVD in short of time. I hope you will get what you want.
Good luck!
sebastian_hill wrote:Hi,I understand your problem, But I use a great CD duplication & DVD duplication service provider when I need to make lot of copy of any particular CD or DVD and it works very well for me. you can get lot of copy of your DVD in short of time. I hope you will get what you want.
Good luck!
Eh?? :con?
Dont think the thread starter is looking for duplication software?
I've found sum freeware software that should do the job;
"Here are some key features of "Apex Free 3GP Video Converter":
� Extreme fast Conversion speed;
� Very Easy to Use.
� Convert mpeg, vcd, dvd to 3GP.
� Convert wmv , asf to 3GP.
� Convert divx , xvid , avi to 3GP.
� Convert mov , quicktime to 3GP.
� Convert rm , rmvb to 3GP .
� Support batch files conversion.
� Specifies start and end position while convert
� No Technical Knowledge Required."
Download it here: http://www.softpedia.com/get/Multimedia/Video/Encoders-Converter-DIVX-Related/Apex-Free-3GP-Video-Converter.shtml
You can try mediacoder as well. It's free, and provides the best quality possible. It's not to easy to use but worth it to spend time.
Cheers,
You can also use the free program titled Super from erightsoftware (just google for super and it should be the first link). This program again is free and converts any format to any format, very easy to use, just drag in the file you want, select what format you want to convert to (right click and select your output folder) and press convert!
